14 years 8 months ago #8120
Replied by 928mac on topic Anyone in Michigan with OB CIS knowledge?
I removed my flywheel without removing the TT or the engine.
You just need this much room, but it is NOT!! easy (and I'm a hard head)
I also took the cats out and replaced it with this muffler shop version that clears the bell-housing
- he_mech_usmc
14 years 8 months ago #8123
by he_mech_usmc
Replied by he_mech_usmc on topic Anyone in Michigan with OB CIS knowledge?
How were you able to get the bell housing back that far? Was it just from unbolting the bell housing, or did you have to shift something to gain that clearance? I don't really want to take the tt out, but I was planning on taking the current exhaust out and fabbing a new one...will be taking ideas on that after I get the new flywheel in...y-pipe to 3 inch to ?
Thanks,
Josh
Thanks,
Josh
14 years 8 months ago #8127
Started with a screw driver, then flat bar then larger bar then I wedged in a wire brush.
It was very technical.
BTW, It you crack or brake the housing, I don't want to hear about it.
If you can loosen the mount bolts it would help
- smtcapecod
- Senior Member
14 years 4 months ago #9427
by smtcapecod
Replied by smtcapecod on topic Anyone in Michigan with OB CIS knowledge?
O/P-- Did you finally win??? :confused:
- he_mech_usmc
14 years 3 months ago #9559
by he_mech_usmc
No win in sight for the near future... getting back into another project...which may be finally running tonight. Self inflicted discouragement didn't help either...as soon as I get back at it I will post more...with pictures
TIA,
Josh
TIA,
Josh
- smtcapecod
- Senior Member
14 years 3 months ago #9565
by smtcapecod
I understand, my first 928 deathmatch was pretty epic, too.
Standing by, we're pulling for you. As much help as that is...
