My Baby Won't Start
15 years 11 months ago #1779
by bstevens
Replied by bstevens on topic My Baby Won't Start
Just a question, I pulled both starter relay and fuel pump relay and the starter relay has 5 prongs and the fuel pump has 4. Can I still switch them with no problems to make the ck? thanks Ben. I do have a multimeter. What reading should I be getting?
15 years 11 months ago #1780
Ben, it is fine to switch them for testing purposes. Doing it Sean's way is faster and less of a struggle. Sometimes those relays can be a pain to remove and it is easy to damage them. Get a jumper wire and bridge across terminal 30 and terminal 87 of the fuel pump relay socket. You should, and I expect that you will, hear the fuel pump run so long as your battery isn't dead.
15 years 11 months ago #1782
by SeanR
Maybe this will help.
Get a small length of wire with spades on each end. Left side is hot, so plug that in last.
