- Thank you received: 10
no voltage
14 years 11 months ago #6019
It will more than likely be your ignition switch. You had power. Then you turned your ignition a second time and had no power. I would remove the switch and look at the back of the lock cylinder just to make sure that it is still turning as it should. If it is, I would simply replace the switch and see if that fixes it. Worst-case scenario... You'll be out $40.
Replied by Kiln_Red on topic no voltage
Stan.Shaw@Excell.Net;6111 wrote: Could be your ignition switch or perhaps a relay. There are many tips at nichols.nu/cat02.htm
14 years 11 months ago #6023
Replied by 928mac on topic no voltage
I think I am going to have to replace my switch this winter.
Sometimes I have to move the key before I see that the Tec-4 connects up.
Everything still seems to work though.
If I was you I would try and visually see if the wires look ok on the switch and if it feels normal when turning it. they get smoother as they where out.
14 years 11 months ago #6024
by monte928
Replied by monte928 on topic no voltage
thanks guys it was my ignition switch. as always if you got a problem you can't figure out post it and someone has an answer. thanks again
