no voltage
15 years 3 weeks ago #5960
by monte928
no voltage was created by monte928
I was starting her up and it started to crank but didn't run the first time but thats normal and when I let go fo the key I lost all my power. I've been troubleshotting but haven't found anything yet. any body have any ideas I can try.
15 years 3 weeks ago #5961
I don't see any details, so please provide more, what year and model, auto or manual, etc. What do you mean by no power? Have you checked the battery to see whether it is charged and the connections are good?
Replied by srshaw3 on topic no voltage
monte928;6106 wrote: I was starting her up and it started to crank but didn't run the first time but thats normal and when I let go fo the key I lost all my power. I've been troubleshotting but haven't found anything yet. any body have any ideas I can try.
15 years 3 weeks ago #5962
by monte928
Replied by monte928 on topic no voltage
Sorry, Its a 1978 euro manual yes I have checked the battery and it has a full charge and the connections are good, I have voltage out to the stud on the left fender
15 years 3 weeks ago #5963
How about voltage to the starter from the battery? There is a direct cable from the rear for that.
You said "no power" but haven't said what that means. Do your lights work? Radio? Does your ignition key allow accessories to be turned on?
15 years 3 weeks ago #5964
by monte928
sorry again, no when I turn on the key nothing works
15 years 3 weeks ago #5965
Could be your ignition switch or perhaps a relay. There are many tips at
nichols.nu/cat02.htm
