%$^* Idler Assembly
16 years 1 month ago #810 by srshaw3
Replied by srshaw3 on topic %$^* Idler Assembly
JE928sx4;843 wrote: You can only get one arm on and not sure about anchoring the other two while I pull.
One arm might work as well as the dent puller option.
Have you tried beating on it a bit with a rubber hammer. It might help with stress if nothing else.
16 years 1 month ago #811 by srshaw3
I did a google search on "crank pulley removal" and there are many thoughts out there...
I didn't like the one where you use the starter..... but there was one suggestion on using a strap removal tool (as used for oil filters) and another on using the 3 arm puller by grabbing the inside lip of a crank pulley. Of course they aren't 982 specific, but it looks like a variety of (just) possible solutions to consider, depending on what tools you have available.
16 years 1 month ago #815 by JE928sx4
Replied by JE928sx4 on topic %$^* Idler Assembly
Stan.Shaw@Excell.Net;845 wrote: One arm might work as well as the dent puller option.
ROFLMAO. Oh I've beat the dam thing all right. :p
16 years 1 month ago #816 by JE928sx4
Stan.Shaw@Excell.Net;846 wrote: I did a google search on "crank pulley removal" and there are many thoughts out there...
Limited in the tools right now.
16 years 1 month ago #817 by srshaw3
Where are you, maybe someone in your area can help?
16 years 1 month ago #818 by Kiln_Red
Replied by Kiln_Red on topic %$^* Idler Assembly
Me neither, but people do it all the time. I guess if one was really careful about it and had a helper on hand to watch the pulley closely, perhaps it would be alright since he is limited with his tool inventory.
