Hood stuck
- rluvsporsche
- rluvsporsche
emmanuelli;15725 wrote: The plastic frame of my hood release was the first thing that broke after i bought it. Since then i bolted a metal bracket to the side with a screw to hold the casing in place and thankfully my handle is working. However the trick is to make sure the casing doesnt move so the wire can do its job, even if you pull it with pliers as i used to do, it was really hard. Unless your wire is stuck somewhere in between this should work.
- emmanuelli
- Elite Member
- emmanuelli
- Elite Member
