Battery brain?
- emmanuelli
- Elite Member
13 years 7 months ago #13710
by emmanuelli
Replied by emmanuelli on topic Battery brain?
thanks alan, i havent done it by the way. my mechanic has the car and is pulling his hairs on it right now.
hoping he can pin point the major issue before long. i'll go the mechanical switch way in the long run, for those times i leave the car stored for an extended period of time.
13 years 7 months ago #13723
by wallyp
Replied by wallyp on topic Battery brain?
While the meter is hooked up measuring the current drain, unplug the fan control module on the passenger side of the panel in front of the radiator. If the drain drops, replace the SCRs in the module.
- emmanuelli
- Elite Member
13 years 7 months ago #13737
by emmanuelli
hey wally, thanks for the tip! i'll look into that and report as soon as possible.
13 years 7 months ago #13799
by Normy1
Replied by Normy1 on topic Battery brain?
I keep a car in Memphis where I work, a 2001 Subaru Outback. The flat-6 will start if it has been 6 weeks since the last start, but more than that the battery goes flat. I use it typically one day per month, so it somehow always starts, but that is the standard for batteries. If your car cannot go 6 weeks between starts then there is a drain, in my opinion.
N
N
