Starting Issue: Need Help
14 years 1 month ago #11119
by Johnny V
Replied by Johnny V on topic Starting Issue: Need Help
14 years 1 month ago #11126
by Johnny V
So I looked into Witchhunter and they have instructions on removing the fuel injector hoses, and I found writeups on replacing those hoses as well. Good news! Since my car was running fine not even two months ago, the probability that they can be successfully serviced by Witchhunter and given new hoses is very high. They will be sent out this week for sure.
14 years 1 month ago #11161
by wallyp
Replied by wallyp on topic Starting Issue: Need Help
The resistor on the temp sensor appears to be a kluge to change the fuel/air ratio.
The black single connector is the power for the AC compressor clutch.
14 years 1 month ago #11168
by Johnny V
I'm wondering if I should even remove that resistor..
14 years 1 month ago #11174
Ummm, No.
With out that I believe it will fry your heater control board (but thats a guess) as I remember this topic on RL.
You may want to do a search and I think it was mentioned during the AC/heater board relay replacement topic
Replied by 928mac on topic Starting Issue: Need Help
Johnny V;11507 wrote: I'm wondering if I should even remove that resistor..
Ummm, No.
14 years 1 week ago #11630
by Johnny V
Got my injectors back from WitchHunter today. I highly recommend them. I dealt with their second shop in Kansas. All of the injectors have new filters, gaskets, caps, and two of them had cracked insulators which were replaced. End result is that all 8 are perfectly matched and flow like new
I can now check off one more thing from my list of culprits.
