Starting Issue: Need Help
14 years 4 months ago #9411
by Johnny V
Starting Issue: Need Help was created by Johnny V
Hello 928'ers
For about two months now my 928 has been sitting in front of my house, motionless. It all started when one day things were fine and I turned it off to go to class, then when I came back, it wouldn't start. It cranked over, but wouldn't fire. Since then, here is what I have done:
-New fuel filter (AdvanceAuto)
-New fuel pump (928Intl)
-New fuel line from pump to filter since mine had a kink in it (928Intl)
-Checked fuel pump relay and even did the jumper trick
-Checked injector relay
-Cleaned ground points (The ones I could get to without a lift)
-New battery
-Took apart upper intake and cleaned everything
-Took out the fuel level sensor and looked inside at the in-tank filter. Seemed fine.
At this point I don't think it's the fuel system since it will sometimes start and idle for about 3 minutes, and then die. After that initial start, it will start for a second or two and die, almost as if it only tries to stay on when the car is cold. I looked at my throttle body and my throttle cable is a little loose, but I doubt that has anything to do with it. Also, there are two sensors by the cables; one that gets pushed when the throttle is full open, and another that seems to get pushed at closed throttle. They look like little gates with arms that get pushed down to hit a button. Anyway, the one that I'm assuming gets pushed on closed throttle isn't being depressed far enough down to hear that "click" of the button push..I don't know if that has anything to do with my issues, but I figure I'll mention it.
I know I need air/fuel/spark for startup, and I am pretty sure fuel is fine at this point, as well as spark, so my suspicions are on the air part of the equation.
Any help would be GREATLY appreciated as I hate to see my car just sit there
-New battery
14 years 4 months ago #9412
Replied by Kiln_Red on topic Starting Issue: Need Help
The sensors you are referring to are the throttle position sensors. They won't be your culprit. Instead, it is probably your temp 2 sensor that has faulted. That would be my first guess by the symptoms you describe. As a 928 owner I recommend getting a complete copy of the WSM. You can do 90% of the diagnostic work yourself with nothing more than simple hand tools and the WSM at your access.
14 years 4 months ago #9413
Also, the temp 2 sensor is a thermistor. To check its function you'll need an ohmmeter. Place the sensor in boiling water. Measure its resistance from one contact to the other the sensor hot. A functioning sensor should indicate a high resistance. A faulty one will usually measure no resistance indicating the circuit for your cold start injector is staying open beyond warm up.
14 years 4 months ago #9416
by Johnny V
Replied by Johnny V on topic Starting Issue: Need Help
Thanks, kilnred, ill check the thermistor tomorrow!
- smtcapecod
- Senior Member
14 years 4 months ago #9430
by smtcapecod
Replied by smtcapecod on topic Starting Issue: Need Help
Have you checked spark by putting a wire (holding it with something insulated) close to the block or another conductive point while cranking?
14 years 3 months ago #9604
by Johnny V
UPDATE:
- Checked the injector harnesses with a Noid light and all 8 checked out fine.
- Checked to see if the plugs were getting spark with an inline light, and they checked out fine as well.
- Tested fuel system by jumping the pump relay and checking how much fuel gets returned in 30 seconds. I got 1.3L of fuel returned to the tank, which is right on.
- Checked the vac lines on the fuel regulators, and none of them smell like gasoline
- Checked the connectors for the MAF, temp II sensor, and cold start injector. All are intact in visually fine.
After all of this, I cranked her over and after 2 tries, she started and seemed to hold idle well. I timed it, knowing it would die soon, and one minute and 40 seconds later, she sputtered and died. Cranked it over again, ran for 20 seconds and died. After this, the car will just crank over but not start. All of this is just as it was since I started diagnostics over a month ago.
I checked the green ignition wire and the insulation at the plug is gone and I see some corrosion on the wire (see picture below).
I forgot to plug it back in and tried starting it, which was a complete failure. I plugged it back in and it started for a few seconds and died, as usual.
Also, I unplugged the temp II sensor to check if the CS injector was working, and the car started but it idled as if it were running on 1 cylinder, SUPER rough. I plugged the sensor back in, and it started and idled well for a few seconds, and died.
Luckily, I'm learning to approach this whole thing with more patience. I'm glad that I have confirmation that my fuel system is running strong, and that all the plugs and injectors are getting pulsed. I'm planning on buying a new green ignition wire since I have been replacing a lot of old stuff anyway, and that is never a bad thing.
Comments?
Comments?
