new belly pan
16 years 2 weeks ago #532
Replied by 928mac on topic new belly pan
ya thats that new 200 amp from MS and I had to mod the bracket to get it to fit.
Original belt
Original belt
16 years 2 weeks ago #533
Replied by srshaw3 on topic new belly pan
Did you let Carl know that it didn't fit right? Someone with less skill than you might struggle with it. I would also wonder if he has any comments on how low it hangs.
16 years 2 weeks ago #534
No I didn't, I thought that it was to use the original brackets but I couldn't make it work.
928racer;562 wrote: Did you let Carl know that it didn't fit right? Someone with less skill than you might struggle with it. I would also wonder if he has any comments on how low it hangs.
16 years 2 weeks ago #535
by 87 Shark
Replied by 87 Shark on topic new belly pan
To low for my ride height. I would loose the whole unit trying to get into the garage. Does the alt. sit lower than the front spoiler?
16 years 2 weeks ago #536
by N2O-928
Replied by N2O-928 on topic new belly pan
Yeah that is low, it looks to be as low as the Front Brake Air deflectors, and they will rub going over speed bump strips.
How could it be so low when Carl mostly sells racing stuff and track cars are not set up high ?
Also I don't see how my stock pan or any would work w/ that Alt.
Dave
Attached files [img]media/attachments/565=56-Pan Front_jpg.jpg[/img]
Dave
16 years 2 weeks ago #537
by 87 Shark
My new pan is comming from 928MS. I just want it to stop the local road kill from ending up as a stew on the undercariage. It should also stop any other debris from going where it does not belong.
How did you mount the new alt.?
