fuel pump preasure
14 years 11 months ago #6766 by whcherman
Replied by whcherman on topic fuel pump preasure
I tested my gauges, and they are good. this is how i made the connection.
1. removed fuel line exiting the fuel filter.
2. attached gauge to the fuel filter.
3. turned on pump
4.gauge reads greater than 100 psi
5. this is the only reference I could find
Walbro Part Number: GCL606
Minimum Current: 12 Volts
Operating Pressure: 58 PSI
Minimum Flow @ Outlet: 38 GPH High Pressure
Fuel Pump Location: In-Line
6. the reason i began investigating in this manner, because i blew fuel pump relay. and i wanted to see if this was a indication of a bad fuel filter or pump.
but both appear to be good. new relays will be here tomorrow.
14 years 11 months ago #6767 by whcherman
www.autoperformanceengineering.com/pics/gsl391.jpg
this would probably be fuel pump spec's. and with zero flow, which was how i measured the psi. it is over 100 psi. but at 60 psi you have established the required flow rate. I believe, I am a chemical engineer not a porsche mechanic, but learning now for 15 yrs.
14 years 11 months ago #6770 by 928mac
Replied by 928mac on topic fuel pump preasure
On the passenger side fuel rail there is a spot to check fuel pressure while the car is running.
This is the normal spot to check pressure so that you can see if the FPR (Fuel pressure regulator) is working right.
I removed my cats so that the exhaust flows better and I ported the heads and I run 56psi. 50 is lots for a stock engine and more is not better in every case.
I hope this helps but it was more then likely just an old relay.
Most on here replace all the relays and fuses just to be safe.
14 years 11 months ago #6773 by srshaw3
Replied by srshaw3 on topic fuel pump preasure
928mac;6899 wrote: Stan can you give James a hand.
It is a member only privilege. I do not find James listed in our membership database.
14 years 11 months ago #6776 by 928mac
Stan.Shaw@Excell.Net;6928 wrote: It is a member only privilege. I do not find James listed in our membership database.
Come on James, loosen up those purse strings and send the $28 big ones ;)
If you want the privilege that is. :rolleyes:
14 years 11 months ago #6777 by whcherman
where do i send it, must have missed that when i registered.
