4 post lift?
15 years 7 months ago #3789 by srshaw3
4 post lift? was created by srshaw3
I think I am ready to buy a 4 post lift.
I want one that:
1. Can be rolled around.
2. Will fit under a 10’ ceiling
I have started reviewing several, and would appreciate any knowledge, pros or cons, of the many brands out there.
15 years 7 months ago #3791 by 928mac
Replied by 928mac on topic 4 post lift?
The rolling around thing is the expensive part Stan.
One of the coolest ones that I have used is the Rotary Lift
directory.groundsupportworldwide.com/pro...raulic_Portable_Lift
Its Pricy though because it is the best.
This bring another note: cheap is dangerous. end of story.
anything under $2500 (canadian) 2 post, is cheap
That said the one below dose not have enough info so I can't tell
I found this post but never checked it out.
stcloud.craigslist.org/tls/2213474913.html
www.completehydraulic.com/
15 years 7 months ago #3792 by srshaw3
Replied by srshaw3 on topic 4 post lift?
You would always need to store a wider car over a narrower car if the rotary lift were used.
I want portable for a number of reasons, not the least that I don't intend to live here forever.
There are a number to pick from in the 4 post world that fall under $2500 US.
Here are a few:
www.eagleequip.com/page/EE/PROD/LI-SS/GLO-8000
www.harborfreight.com/automotive-motorcy...rage-lift-68481.html
www.northerntool.com/shop/tools/product_200349258_200349258
www.backyardbuddy.com/automotive-lifts/b...000-lb-4-post-lifts/
www.bendpak.com/car-lifts/four-post-lifts/HD-7P.aspx
15 years 7 months ago #3794 by 928mac
Ya You have to spend more on a 2 post to get a good one.
The 4 post like you have listed all seem to be fairly good quality.
I would pick the eagle as a first choice, but with out the specs on some of them it is hard to compair.
As much as the back yard buddy seemed like it would be a cheap hoist, it also seams like a good pick.
By portable I thought you ment that you could roll it out to the drive way and lift a car 7 feet in the air. That is why I sent you the rotary lift link.
I have used them to lift a trackor trailer truck and you just roll the post up to each wheel and lift the vehical with its own tires.
15 years 7 months ago #3795 by srshaw3
Good thoughts, thanks.
A key use I expect will be in the winter when cars are in storage, so one car will sit over another for months.
15 years 7 months ago #3796 by 928mac
Ya this would be a hard choice.
All of the ones that you posted look fairly safe which should be the main concern.
The harbor one looks good to.
Still If I knew that I wanted to by a quality unit, I would go with a name brand.
It looks like that buddy one has wheels on it and you may be able to stack cars with it.
