Just bought my first 928 !!!!
14 years 6 months ago #8675 by Pauls 86.5
The first time I opened the hood I was a little over whelmed the cars I use to work on had like one vacuum line to the distributer. Last weekend I took the air cleaner apart and started looking at vac lines and am trying to get use to everything. My hawks rear pads came today so I know what I will be doing sat.
14 years 6 months ago #8676 by Pauls 86.5
Brad is there any way to get a better idea if the belt has Ben changed or should I assume it's old and just dig in
14 years 6 months ago #8677 by 928mac
Pauls 86.5;8850 wrote: Brad is there any way to get a better idea if the belt has Ben changed or should I assume it's old and just dig in
Can you phone the person you bought it from?
If the Prev owner (PO) is not available then you need to inspect the belt.
Some look through holes but really the covers need to come off.
A new belt should last 50-80,000 but they are not made to be run hard when they are 10 + years old.
I replaced my belt after 1 year because it got oil on it due to I did not repair the leaks under the intake.
when you get to that point, if the po can't be reached, remove the covers and take pictures for us to look at.
BTW look at the names and address under the road side assistance thread to see who is in your area.
14 years 6 months ago #8678 by 928mac
Here is a good read on Rennlist
forums.rennlist.com/rennforums/928-forum...checking+timing+belt
And here is a link from our Technical library on the home page
forums.928oc.org/vbulletin/showthread.php?t=587
14 years 6 months ago #8696 by Pauls 86.5
WOW ! Now that's a detailed list on how to do the timing belt! Thanks Brad
14 years 6 months ago #8697 by 928mac
Pauls 86.5;8870 wrote: WOW ! Now that's a detailed list on how to do the timing belt! Thanks Brad
Dwayne Heinsma is the one we need to thank for all of the awesome hard work he put into these detailed step by step how to instructional.
