Resources!!
14 years 7 months ago #8409
by denhamfly
Resources!! was created by denhamfly
I am looking at changing out my injectors, wiring harness and vacuum hoses. Where would one go to get this items?
14 years 7 months ago #8410
The first person I would call would be one of our vendors.
Replied by 928mac on topic Resources!!
denhamfly;8583 wrote: I am looking at changing out my injectors, wiring harness and vacuum hoses. Where would one go to get this items?
14 years 7 months ago #8411
I expect any of the vendors can help you on the injectors. I think I recall the use of Ford injectors as a good replacement, but that is only a memory of a post that I wasn't focused on at the time.
A 928er put together a vacuum hose replacement kit, and I bought it from him. I think Roger of 928srus.com took on the kit, with improvement, after the 928er lost interest.
Of course times change, all or no vendors could have both now
Replied by srshaw3 on topic Resources!!
928mac;8584 wrote: The first person I would call would be one of our vendors.
14 years 7 months ago #8415
by denhamfly
Replied by denhamfly on topic Resources!!
It is a sad day in mud vile when a ford has the same injectors as my Porsche, I will investigate that. Thanks for the info.
14 years 7 months ago #8420
Hey Oscar; they may even be from the racing division but I'm not sure.
I do know that the 928 group has been doing lots of testing.
I think there are 3 versions.
The biggest and best difference is the 3 hole version. but
I think the last version will slide to far into the intake.
For more info on this I would call Roger at 928rus and talk to him.
BTW we have 19lb injectors. on a stock engine anything more then 24lb will cause over fueling and I think you will still need to retune with the 24lb but I am not sure. Call Roger and ask what the lastest info is on the 3 hole ford injectors and what he recommends.
denhamfly;8589 wrote: It is a sad day in mud vile when a ford has the same injectors as my Porsche, I will investigate that. Thanks for the info.
14 years 7 months ago #8424
by the flying scotsman
Replied by the flying scotsman on topic Resources!!
They're not Ford injectors (Bosch IIRC) but made to fit many Ford engines which with the correct Orings fit the intake and fuel rails of the 928.
The benefit over the OEM injectors is $$$$......you can buy all 8 of the Ford version for less than 2 of the OEM.
Also, you should request the 4 hole version which should give a better spray pattern than stock and as Brad mentions they are 19lb.
