1983 AU Car Idle speed
7 years 3 weeks ago #20954
by foxint
1983 AU Car Idle speed was created by foxint
Hi Guys.
Been without my 1983 928 for almost 2 years. Now doing some shake-down driving. Drove it to Sydney (about 400km) 2 years ago and drove it back on Sunday (2019-09-08).
Lots of things not working at the beginning of the trip and some now working…ha-ha….
My stupid question as google was unable to tell me:
What is the recommended idle speed for the 1983 AU (World model) mine seems not to want to go above 400rpm. The idle adjustment screw seems to do nothing???
D
D
7 years 3 weeks ago #20963
by Trainer
Replied by Trainer on topic 1983 AU Car Idle speed
what happens when you switch on the air AC, does the idle speed go up or down.
7 years 3 weeks ago #20964
by foxint
Replied by foxint on topic 1983 AU Car Idle speed
Hi Karma
Thank you for the reply.
I made a mistake I have a 1982 car.
The A/c does not work. I took it for a country run yesterday about 30mins (I live in the country – so getting to high speed roads (100km…not exactly high speed). Then came home, turned the throttle screw and basically nothing happened. In park the car idles at about 400rpm. The red changing light does not appear – so that is good.
D
D
7 years 3 weeks ago - 7 years 3 weeks ago #20965
Replied by Rich928 on topic 1983 AU Car Idle speed
Hello Foxint,
Your 1982 Porsche 928 Euro/ROW uses Bosch CIS fuel injection, whereas the US/Japan models used Bosch L-Jetronic fuel injection. Your engine should idle at 650 - 750 RPM (US/Japan are speced at 725 - 800).
The CIS injection CO % (air/fuel ratio) should be 1.0 to 2.0% measured at the tail pipe. The adjustment is at the fuel distributor. It is a VERY sensitive adjustment. The screw only needs to be turned a small amount for a change. It is getting difficult to find a garage that has a CO% meter since most modern cars no longer have air/fuel adjustment. The 1987 and newer 928s have no adjustment. A shop that services old cars with carburetors may have such equipment.
[US/Japan cars use a catalytic converter, CO% cannot be measured at the tail pipe which is after the catalytic converter, the spec is 0.4 to 0.8% CO before the catalytic converter].
If the idle speed doesn't change at the screw, the port may be plugged. Idle speed is increased by allowing more bleed air into the air intake system.
The 928 tachometer may not be very accurate at low speeds. An external tach may provide a more accurate reading.
Last edit: 7 years 3 weeks ago by Rich928.
