Removing Hood Insulation Adhesive
- Burlingame
10 years 3 months ago #19144
by Burlingame
Removing Hood Insulation Adhesive was created by Burlingame
Does anyone know the best way to remove the adhesive for the hood insulation. I have removed all the crumbling foam insulation and suspect I will need to remove the old adhesive before I can install a new liner.
10 years 3 months ago #19145
by joejabq
Hi,
I used odorless mineral spirits and those green scotch pads, I think.
Here's A link to Dwayne's write-up.
dwaynesgarage.norcal928.org/1987%20Hood%...20Liner%20Repair.htm
Replied by joejabq on topic Removing Hood Insulation Adhesive
Burlingame wrote: Does anyone know the best way to remove the adhesive for the hood insulation. I have removed all the crumbling foam insulation and suspect I will need to remove the old adhesive before I can install a new liner.
Hi,
- Burlingame
10 years 3 months ago #19146
by Burlingame
Replied by Burlingame on topic Removing Hood Insulation Adhesive
I will try that next. Thanks
10 years 3 months ago #19147
by joejabq
Good luck! It should clean up well. I remember now that using brushes helped too.
Burlingame wrote: I will try that next. Thanks
- Burlingame
10 years 3 months ago #19154
by Burlingame
Well after trying a number of products to remove the adhesive with no success I decided to just stick the new insulation to the old adhesive. It worked awesome and I don't think there is any chance of it coming off. So if anyone else is replacing their hood foam I would say just remove the old crumbling one with a shop vac and install the new one right over top of the old adhesive. Now on to the next project, brakes.
10 years 2 months ago #19258
by jwood
Replied by jwood on topic Removing Hood Insulation Adhesive
i used the 3M adhesive remover thru Amazon, worked great.
