"Clunk"
10 years 3 months ago #19116 by 1988928
Replied by 1988928 on topic "Clunk"
K I have not looked at crank shaft well be looking at that soon. Also plan on taking a look at cv joints. That same day I was planing on doing a once over on the trans and flex plate lucky for me she is not my daily driver. The vibration starts when I hit haighway speeds I didn't even notice until a buddy of my pointed it out to me. So I honestly think the cv joints are going and that is causing the vibration and to get to flex plate I have to drop the rear end anyway so I figured do it all at once. Let me know if this also a bad idea.
10 years 3 months ago #19117 by billvvSU
Replied by billvvSU on topic "Clunk"
Does it vibrate in Neutral? If so, it's not the CV joint.
You can isolate the engine from the drive train by disconnecting at the front flex plate.
I haven't done it, but I believe you can do the same at the rear flex plate by disconnecting it from the torque converter. That should tell you whether it's the torque tube or not - assuming it's still there after the front flex plate is reconnected.
