1983 928 wheel/tire combo
10 years 8 months ago #18850 by todd1983928
Hello everyone, first time on 928 Owners Club and I'm hoping to gain knowledge and help for my newest project.
1983 928s with 5-spd. (which needs a restoration inside and out but runs and drives!!
I'm learning a lot and still have tons of questions.. So thank any/all of you in advance!
my 928 currently has 16" phone dialers and I am searching the net for a good used set of wheels/tires (preferably something different than dialers) and hoping to gain some knowledge on wheel size and tire size and wanting to upsize to 18" wheels. I don't understand the 'offset' numbers yet and hoping someone can help me with that also.
Todd
10 years 7 months ago #18901 by The Deputy
Off-set, negative or positive, is the measurement of the rims width when taken at the rim/rotor mounting surface and the inner or outer edge of the rim. Negative is from the rim/rotor mounting surface to the inner edge, positive is from rim/rotor surface to outer edge.
Brian.
10 years 7 months ago #18904 by jmwise
Replied by jmwise on topic 1983 928 wheel/tire combo
The Deputy wrote: Off-set, negative or positive, is the measurement of the rims width when taken at the rim/rotor mounting surface and the inner or outer edge of the rim. Negative is from the rim/rotor mounting surface to the inner edge, positive is from rim/rotor surface to outer edge.
Brian.
Brian, I believe your definition is for back-spacing. Offset is measured as the distance between the mounting surface of the rim to the center-line of the wheel and can be a positive or negative number from this line.
Our cars utilize positive offset wheels with a relatively high offset measured in millimeters. The front wheels cause the most frustration with most years using a stock ET65 offset. It can be confusing, as in our application a larger number offset actually locates the wheel further inward, all other things being equal. A lower number offset actually locates the wheels further out. Seems backward until you think about it. As most other Porsche wheels have much lower offsets than 928 wheels, most will not work, particularly wider wheels on the front - as the combination of wider rim and a lower offset combines to "push" the wheel/tire combo out past the fender and will result in rubbing.
Here's a link to the "bible" of 928 wheels and suspension, with good definitions, illustrations, and explanation of why our cars use such a relatively high offset: www.landsharkoz.com/forms/928wheels.pdf
Jarrod Wise
90GT
928 Registry Chair
10 years 7 months ago #18911 by The Deputy
Yes, you are correct Jarrod. I had some sort of brain-fart while typing that reply.
Brian.
