1982 928 Timing Belt Spec Question
11 years 9 months ago #17945 by JohnnyDiesel
I have a 1982 928 base model, 4.5L v8 engine, and upon inspection found that it has a round tooth timing belt and gears. Will the 1983 belt (round tooth of course) work on this engine? Clearly the previous owner changed the original set up sometime in the past, and i need to order a new one due to age. Since the 82 is the 4.5L and the 83 is 4.7L, i just need to clarify whether the belts are compatible. Thanks!
