This is the optional category header for the Suggestion Box
forums location
6 years 4 weeks ago #21410
by Sterling
forums location was created by Sterling
Can we switch the forums around in the order? Make the technical forum the 1st forum at the top of the page. It will make it easy for the folks that are leaving rennlist behind.
6 years 3 weeks ago #21418
by billvvOC
Replied by billvvOC on topic forums location
Hi Sterling,
I met you some years ago here in Seattle with Tom, Adam, and some others at a burger joint. Thanks for your suggestion. I see you've recently joined, so you can see the post in the Board Discussions sub-forum where your suggestion was introduced. It's a great idea and pretty easy to accomplish. I am the one that will do the bit twiddling to make it happen, so as soon as there's consensus I can get right on it.
