FS: 1991 928 GT
10 years 4 months ago - 10 years 4 months ago #19036
by 944Cup
FS: 1991 928 GT was created by 944Cup
For Sale: A very nice example of the 928GT in Grand Prix White and black interior. In very good condition inside and out along with motor and transmission. 5 speed manual. Matching numbers. Paint original and near perfect condition with no dents, scratches, dings or chips. Runs perfectly, everything works. Original paint and interior with clean accident history.
I am the 4th owner. The car is currently located in Charleston, SC. Mileage is 160k. Car has been extremely well cared for by each owner and have maintenance records from the original owner. Car drives and shows like new.
First owner was In California, where Niello Porsche did all service and repair…. Extensive records from them up to 120k miles…. None of this work is internal motor work. Clutch at 120k. Steering Rack, Fuel Pumps and Filter at 103k. LH Control Unit was replaced at 65k. Many other service records available.
Second owner was in Arizona and had service done at Redline Motorsports…. They did IAC Valve, MAF Sensor, Knock Sensors, Temp 2 Sensor, Radiator, etc, at 122k, along with Bilstein shocks and Eibach springs.
Third owner continued with a thorough maintenance approach replacing for example: brake master cylinder, installed short shifter, Installed Fuel Pressure Gauge, Silverstar Headlights, Solid Motor Mounts, clutch slave cylinder, GTS side view mirrors,etc.
Within last 500 miles replaced the battery, distributor caps and rotors, timing belt, water pump and updated Porken tensioner was done by European Road and Racing in North Charleston, SC.
Compression Test @ 150k: 1-176, 2-175, 3-177, 4-175, 5-178, 6-180, 7-175, 8-176
Car comes with 2 sets of wheels, original 16' wheels plus a set 18" gloss black powder coated new finish factory wheels 18X8 FRONTS 18X9 REARS (ET 59 FRONTS / ET 53 REARS ). Tires on both sets of wheels are like new with under 1,000 miles.
Buy the car now for $28,000. Will consider all offers over $20,000. Email Dave at cup944@aol.com
Last edit: 10 years 4 months ago by 944Cup.
