Wanted Big Brakes
13 years 9 months ago #12914 by Kiln_Red
Replied by Kiln_Red on topic Wanted Big Brakes
malcolm;13136 wrote: what is wrong with the OEM brakes?
I drove a 82 at the 3rd coast event in Texas and that car could stop.....be even better with newer rubber.
Might be worth considering a fresh set of hi perf pads and new rubber........save on $$ and much r&r time........remember bigger brakes need bigger wheels.
Brilliant post, Malcolm. I think you echo my thoughts about brake upgrades. I understand the cosmetic reasons for doing brake upgrades. Aside from that reason, all 928s have excellent braking ability as stock. A brake upgrade would be one of the very last investments that I would consider making in a 928 unless a very unique opportunity came along that allowed me to do it for an exceptional price.
13 years 8 months ago #13331 by bugnbox
Replied by bugnbox on topic Wanted Big Brakes
Ive got a 79 928 and just got an S4 with a blown motor basically for free...Ive been thinking of doing the brake swap too...heck...thinking of swapping as much as I can over from car to car if any of it is really an improvement.
13 years 8 months ago #13347 by Ducman82
Replied by Ducman82 on topic Wanted Big Brakes
i swapped in a set of GTS brakes due to a good deal i got. but the stock S brakes i had were damn good.....
13 years 8 months ago #13439 by 77Tony
Replied by 77Tony on topic Wanted Big Brakes
Installed 330's up front & 300's rotors on the rear with Wilwood 4 piston calipers all around on my 80. I sanded the Wilwood script off & had Ben at Legend Garage powdercoat, clear & stencil them. Contact: xschop over on RL, he makes adapter's that make it super easy & less expensive. No need to change out spindles either. A little cutting on the dust covers & your good to go. If you want to go really big, xschop is now making adapters for 6 piston calipers up front & installing them on his 78. T
forums.rennlist.com/rennforums/928-forum...30mm-rotor-swap.html
Attached files [img]media/attachments/13797=1624-exhaust%252082%25206%2520spd%2520008 (640x480).jpg[/img] [img]media/attachments/13797=1628-IMG_0006.JPG[/img] [img]media/attachments/13797=1626-LEFT-RR.JPG[/img] [img]media/attachments/13797=1625-smaller2 (640x428).jpg[/img]
13 years 8 months ago #13440 by ndfrspd
Replied by ndfrspd on topic Wanted Big Brakes
77Tony;13797 wrote: Installed 330's up front & 300's rotors on the rear with Wilwood 4 piston calipers all around on my 80. I sanded the Wilwood script off & had Ben at Legend Garage powdercoat, clear & stencil them. Contact: xschop over on RL, he makes adapter's that make it super easy & less expensive. No need to change out spindles either. A little cutting on the dust covers & your good to go. If you want to go really big, xschop is now making adapters for 6 piston calipers up front & installing them on his 78. T
Nice upgrade, I don't think I'll need that much braking even though My perception has always been You can never have too much braking power. ndfrspd
