where to install the rad flush tee
16 years 3 months ago #417
where to install the rad flush tee was created by 928mac
I was thinking of installing the flush tee in the front 1 inch hose that connects between the rad hoses.
what's your thoughts
16 years 3 months ago #418
I'm a little confused I guess. Are you talking about the hose that travels from the expansion tank to the t-stat housing? If you're wanting to do the whole system at once then I think that would be a very effective place to start if I'm on the same page.
Replied by Kiln_Red on topic where to install the rad flush tee
B.W.Haugen;441 wrote: I was thinking of installing the flush tee in the front 1 inch hose that connects between the rad hoses.
16 years 3 months ago #419
Replied by 928mac on topic where to install the rad flush tee
Ya I was thinking of putting a 10 min rad flush solution and then I would connect a hose to the tee, open the rad drain and let the engine run till the water runs clean.
16 years 3 months ago #420
Can't think of any way to improve off of that idea. Go for it.
