ABS PSD Warnings after bump on '90 GT
14 years 10 months ago #7083
ABS PSD Warnings after bump on '90 GT was created by srshaw3
Since getting my '90 GT back from service, the ABS & PSD warnings are displayed apparently after the first significant bump. Often they display at the same time, but sometimes the PSD followed by the ABS.
I am presuming it is a loose connection, and more likely rear of the car related since I don't think the PSD would care what happens at a front wheel. Any thoughts on what connections and where to check? Perhaps removing the two grounds at each rear wheel to start? They seem solidly connected when tugged at a bit.
14 years 10 months ago #7085
by the flying scotsman
Replied by the flying scotsman on topic ABS PSD Warnings after bump on '90 GT
The ABS and PSD circuits are linked through the fuse/ relay panel.....I'd check the relay (XV) to start.
Has the PSD system been serviced (fluid flush)?
14 years 10 months ago #7086
I will re-seat the relay, inspect the pins, etc.
Yes, the PSD was flushed a year ago and operated fine after that. I suspect this issue has arisen due to the quite a bit of electrical diagnosis type work that was performed.
Thanks Malcolm.
Replied by srshaw3 on topic ABS PSD Warnings after bump on '90 GT
malcolm;7245 wrote: The ABS and PSD circuits are linked through the fuse/ relay panel.....I'd check the relay (XV) to start.
Thanks Malcolm.
14 years 10 months ago #7087
no worries Stan.......beyond the relay Id look at the controller and the ABS sensors.
We are a captured audience for ~4 mths......damn winter:eek:
14 years 10 months ago #7092
The rear abs sensors were my first thought.
I anticipate I am looking for a component in common between the ABS and PSD.
Do you know if they are used by the PSD?
Do you think I should remove clean and reinstall? Just looking at them I don't see an issue.
14 years 10 months ago #7098
Yes, the ABS sensors are part of the shared PSD circuitry.
Yes, they can be cleaned, I use use brake cleaner and a small brush (toothbrush).
There are resistance spec for the ABS sensors.....let me find them
