Fuel Stabilizer
14 years 11 months ago #6796 by 928mac
Replied by 928mac on topic Fuel Stabilizer
babromovage;6950 wrote: Wow. Varying opinions. Not sure what I should do. I would like to add a few points that may offer recommendation. The car will be stored in a temperature controlled car storage facility.
Brian
Brian, it is up to you. IT dose not hurt to leave gas in it.
It is better to have a full tank then a 1/4 tank.
I just drain mine because it is in my home on a heated floor and because I normally will be doing some kind of work on it.
I would not recommend putting in an additive unless you can be sure that it will not react with the plastic tank and other components in the fuel system.
This is my humble opinion.
14 years 11 months ago #6798 by srshaw3
Replied by srshaw3 on topic Fuel Stabilizer
I have used Stabi in a variety of applications for many years: www.goldeagle.com/brands/stabil/faq.aspx
14 years 11 months ago #6800 by 928mac
Stan.Shaw@Excell.Net;6953 wrote: I have used Stabi in a variety of applications for many years: www.goldeagle.com/brands/stabil/faq.aspx
Wow! that is really good information Stan.
We really need to save these information links in one area
14 years 11 months ago #6801 by srshaw3
928mac;6955 wrote: Wow! that is really good information Stan.
We could create a catch all of valuable links in a single topic on the technical library that you would maintain.... Does that work?
14 years 11 months ago #6802 by 928mac
Stan.Shaw@Excell.Net;6956 wrote: We could create a catch all of valuable links in a single topic on the technical library that you would maintain.... Does that work?
sounds good.
show me what you have in mind
14 years 11 months ago #6803 by srshaw3
928mac;6957 wrote: sounds good.
Go to: forums.928oc.org/vbulletin/newthread.php?do=newthread&f=16
Enter for "Title:"
$Links to External 928 Areas of Interest"
(the "$" should keep it at the top of the sorted forum)
Enter for "Message:"
An alphabetized list to sites of interest to 928 owners.
By doing the above, you will own the topic. I will then edit it, to show you my ideas on the content structure.
An alternative we could have a separate forum, with one topic per website, sorted by a structured topic ID, but that might be overkill right now, and there are quite a few forums already.
