Oil Pressure Question
- dwarner928
14 years 11 months ago #6552
by dwarner928
Oil Pressure Question was created by dwarner928
Ihow high should my oil pressure be at road speed. Under acceleration I'm hitting 5 bars+ but at road speed around 70mph I'm at 4-4.5. Is that normal?
Also the shift points seem high...is that just the car? I'm trying to get to know her without hurting her...
14 years 11 months ago #6553
Replied by pcar928fan on topic Oil Pressure Question
Doug,
I guess your car is an auto... Under full throttle there is a button under the gas peddle that will be depressed and the car should run to redline. If you are just taking it easy, normal shifts (again depending on throttle position) should be around 2500 (light throttle) to maybe 3500 or 4000 with moderate to a bit more but not FULL throttle... That is just from memory from my last drive.
The oil pressure numbers sound spot on.
- WyattsRide
14 years 11 months ago #6564
by WyattsRide
Replied by WyattsRide on topic Oil Pressure Question
In my 5 speed, at road speeds or load, the OP gauge is pegged. At idle it drops to about where you describe or a little lower. This is also from memory. :confused:
14 years 11 months ago #6572
Replied by 928mac on topic Oil Pressure Question
Hello Rick.
When engines start up cold you are looking around 125psi or 8 bar.
when they are hot at an idle (depending on ware) and oil (15-40/15-50 oil)
it may drop to 3 bar or a hair under.
Remember that the gauge may be out a bit one way or another.
14 years 11 months ago #6673
Replied by mm928 on topic Oil Pressure Question
Hi Rick,
Brad is on it, the thing with Porsches is that the gauges are actually supposed to be accurate and work! So if it is working normally, you will indeed see fluctuations with the pressure, at least for an Automatic as I have. The important thing is that it looks responsive and immediately goes to full bars as needed according to RPMs. When cruising, I notice that the gauge will be below full bars like Brad said, but if you add revs...it goes immediately to the top. As the engine gets hotter, it may vary a little differently, also depends on oil weight etc. as Brad said. Sounds like it is easily within range.
Check the level often just to be sure, but it is quite amazing that after 27 years, my engine hardly uses a drop of oil between yearly oil changes. Awesome cars when they are right!
