headlight washer
15 years 1 month ago #6175 by john a. volak
can anyone help me? my driver side headlight washer is not working but drips to the ground. i know how to disassemble the front end but is there anyway to get line hooked back up by taking off fender shield? any help will help. thanks, john
15 years 1 month ago #6193 by pcar928fan
Replied by pcar928fan on topic headlight washer
John, I don't think there is ANY easy way to work with that... I say eliminate it completely! For me they have been completely POINTLESS!
15 years 1 month ago #6195 by 928mac
Replied by 928mac on topic headlight washer
Do you have the WSM?
I dont know if it is in there but it should be
15 years 1 month ago #6199 by the flying scotsman
The washers can be very helpful if your at uber speeds, its dark and you might need to see :)
As the hood nozzels plug up so do the headlight ones......take a pin or needle and clean the tiny orfices. If you need to reattach the hose(s) the front wheel inner fenders need to come off.
Good luck.
15 years 4 weeks ago #6215 by john a. volak
Replied by john a. volak on topic headlight washer
thank you for info. i will try cleaning nozzles, and remove inner liner. this website is great. john
14 years 10 months ago #7096 by mm928
Replied by mm928 on topic headlight washer
Hey - anyone tried to just cap the headlamp washers off from the rest of the washer system? Any good way to do that?
If not maybe I will see if I can plug the lines etc. I also do not think it is worth the effort unless I am going to remove the front bumper for some other reason as well. My passenger side is doing the leaking thing if it is filled up and pressurized.
Also my main wiper linkage is noisy, like it must be loose somewhere. I think I can get to it behind the plastic shield, will take a look maybe over the holidays.
