Where should Map sensor Vac be connected
15 years 2 months ago #5755
Where should Map sensor Vac be connected was created by 928mac
I am not getting a good map signal as the vacuum is tee'd into the source on top of the throttle body closest to the firewall.
I am wondering if under the TB would be a better spot to draw Map vacuum from?
here is a pic of the spot under the Throttle body that I am thinking of.
15 years 2 months ago #5757
Replied by Kiln_Red on topic Where should Map sensor Vac be connected
Looks like it should yield the same results in either point to me. :confused:
15 years 2 months ago #5758
Replied by 928mac on topic Where should Map sensor Vac be connected
Thanks Austin.
What I was trying to figure out is if it is ported and if it may give me a stronger signal under load. It just about looks like the throttle plate may close on it.
I can't find any specs or anything in the WSM
