Hot car electrical gremlins.
15 years 2 months ago #5682 by Kiln_Red
Alright, Brad. I'll give it a shot. Thanks for the tip. If not, I can try the connector from my parts car. One way or another I'll get it straightened out.
15 years 2 months ago #5683 by 928mac
Replied by 928mac on topic Hot car electrical gremlins.
KilnRed;5828 wrote: Alright, Brad. I'll give it a shot. Thanks for the tip. If not, I can try the connector from my parts car. One way or another I'll get it straightened out.
It may be the pigtail like you say Austin.
That may be where the high resistance is. between that bulb socket or the wire connected to it.
But it will be on the ground side where the poor connection is.
Replace the socket and if it still has a dim glow through the other side bulb, install another ground.
15 years 2 months ago #5684 by WyattsRide
KilnRed;5817 wrote: My '84 has the same issue with the brake light indicator. In my case, I need a new pigtail. A friend following me along one night noticed that when I used my signal the brake light was actually intermittently flashing as a turn signal should while there was no activity at all from the marker on the lens. Rick, are you sure that you're noticing these gremlins more in hot weather and that it may not just be coincidental? How does it act in rain or humid weather?
Well, I can't say for sure that it's the heat. But, most of my driving is in the spring, summer and fall. In the spring and fall (cooler weather) these issues don't seem to arise. In the summer they do. Usually here, when it's hot (80's - 90's) it's also humid. My car doesn't see much rain. But, when it has, no issues.
