Timing belt
15 years 3 months ago #5438 by denhamfly
Replied by denhamfly on topic Timing belt
I will get out my best glasses and look again for the mark, I did not see them, but will look again. I do really appreciate this help!
15 years 3 months ago #5439 by Landseer
Replied by Landseer on topic Timing belt
Below are a few pictures to help.
One shows the passenger cam gear mark, typical half tooth off, while drivers is dead-on.
Another shows the tensioner arrangement.
(IIRC, Dwayne's writeup might have not shown that washer labeled #4.)
Tensioner arm changed slightly after your 85 model year. Different casting, different offset dimensions so that the line of force applied to the tensioner roller put less twist on the pivot bolt. I mention this only to prevent you from worrying about very minor difference from Dwaynes pics on that subject.
Attached files [img]media/attachments/5579=643-85 Tensioner Image3.jpg[/img] [img]media/attachments/5579=642-timing gear indentation mark OC size, 85.jpg[/img]
15 years 3 months ago #5440 by srshaw3
Replied by srshaw3 on topic Timing belt
The Porken timing tool allows setting the timing dead on, as I recall, so that would help as well.
15 years 3 months ago #5441 by Landseer
In your pictures that Stan shared with me the car is not at TDC.
The rotors should point roughly to the three O'clock position when at TDC (one is slightly different than the other, but close to 3 O'clock). Then, at that position, with harmonic balance at O/T, the nicks become visible and aligned.
Your rotors, as shown in your pictures, are more like the 10 O clock position.
I show below the position of the passenger rotor at harmonic balancer O/T (TDC).
Hard to see due to resolution, even by zooming with ctrl key / spinning mouse wheel -- but my rotor points sort of towards 3 O clock, in line with the timing warning wire that is hanging there.
The marks on the front of the cam gear are not relevant. Those pill shaped indentations mean nothing to the alignment.
The alignment nick-marks on the rear edge of the cam gears, behind them so-to-speak, are what you are looking for. These critical nick marks are not visible until the car is more closely approaching TDC. Your's might be closer to 45 deg btdc in your pictures.
One fact that bothers me about the process --- with crank locked per instructions at 45 degrees before TDC, when removing and replacing belt---- you don't have visiblity to the cam gear marks to ensure one camshaft didn't move while the belt was off. So most of us make separate reference marks on front of gears with a magic marker --- just to confirm they didn't move relative to each other while you are doing all the other work before putting the belt back on.
Attached files [img]media/attachments/5581=644-TDC and rotor postion.jpg[/img]
15 years 3 months ago #5444 by denhamfly
Thanks< I guess I missed seeing the mark I will check it out when I get home.
15 years 3 months ago #5446 by Landseer
Let us know.
Also, as a precaution before you get started with the project, take a hard look at the harmonic balancer for proper fitment/orientation.
When you stand in front of your car and face the engine, the white numbers printed on the harmonic balancer should be oriented for easy reading.
They should not be "upside down" when reading them.
(The unit fits both ways --- but it will indicate wrong crank positions if upside down --- making a world of problems for the "next guy replacing the timing belt" --- read "you". Gotta check that before disassembly)
