Oil plug use a washer or not?
15 years 3 months ago #5294
by EWM
Oil plug use a washer or not? was created by EWM
The oil drain plug on the recently acquired 1979 928 does not have a gasket or washer on it.
I see pictures of both rubber O rings and aluminum flat washers on 928 web pages that seem to be assocaited with 928 oil plugs. Does the oil drain plug use a washer, O ring or nothing?
There is slow oil drip coming from this area or at least was befoe I drined the used oil.
Thanks,
EWM
1979 928
Thanks,
EWM
1979 928
15 years 3 months ago #5295
Replied by srshaw3 on topic Oil plug use a washer or not?
I have always used the flat crush washer on my 928s. Usually the 928 vendors include it with an oil filter. I think this will correct your drip next time you change the oil.
15 years 3 months ago #5296
by EWM
Replied by EWM on topic Oil plug use a washer or not?
Can anyone suggest a buiness that would sell a crush washer. One did not come with the Bosch filter I bought from Parts Geek. I cannot find one on eBay. The parts store linked to 928Tips may be on vacation today. The Auto Zone store does not have one that fits. They did have a 60 cent generic rubber O ring but i don't know if that would hold up to the heat.
I would like to find a trust worthy washer as I am not going to pour in $60 worth of synthethic oil that I would lose to stop the oil leak. Meanwhile I can't drive the car this weekend becasue of a two dollar washer.
15 years 3 months ago #5297
A quick search finds it to be sized 22 x 27x 1.5 mm part number 900-123-118-30-M131 (you should confirm this).
Where are you located, you might want to pick the vendor to get it from based on that. You are likely to pay more in shipping than for the crush washer.
928 vendors are your friends; 928intl.com and 928srus.com (I suspect you tried 928gt.com from the tips site).
15 years 3 months ago #5298
by EWM
I am located in north central San Antonio, Texas.
Which of the two vendors would you suggest? Or is there a closer recommended source?
I have a list of small things I need to but for repairing all the minor (so far) issues found with the car.
Thanks,
Woody Montier
Thanks,
Woody Montier
15 years 3 months ago #5299
928srus.com is in TX
928intl.com is in CA
928gt.com is in NC
928gt.com is in NC
