central warning system
15 years 3 months ago #5237 by john a. volak
1998 s4, when hitting a small bump, central warning light comes on, also brake pad light in dash comes on. when hitting warning light switch on dash it goes off. all brake sensors are gone how do i fix problem? i check brakes every year and they are great. i read somewhere how to disconnect sensors if this is the problem anybody know how to accomplish this? i like to do things right so would it be better to replace sensors? i have had so much accitance with this web site that makes things work. thanks so much for your help, john
15 years 3 months ago #5238 by N2O-928
Replied by N2O-928 on topic central warning system
Hi John, to disable the sensors at each wheel all you need to do is to tie the two sensor wires together. I have seen this done on an '80.
The sensors are not very expensive, I would just replace them with new and check all the connections for good contact, WD-40 is your friend when it come to electrical connections.
Good luck,
Dave
15 years 3 months ago #5389 by john a. volak
thanks dave, i.ll try this and see what happens, john
15 years 3 months ago #5391 by WyattsRide
Replied by WyattsRide on topic central warning system
john a. volak;5377 wrote: 1998 s4,.........
Huh? :confused: ;)
15 years 3 months ago #5395 by 928mac
Replied by 928mac on topic central warning system
John must mean an 89 not a 98.
Thats why its always good to have your car in your sig ;)
15 years 3 months ago #5409 by john a. volak
sorry guys, it is a 1988 not 98. thanks john
