88 Cam Gear Replacement
15 years 4 months ago #5041 by Slave01
Any trick to replacing cam gears, other than finding cam gears for replacement? Currently in mid-timing belt R&R, discovered worn cam gears, getting ready to pull the old ones. Thanks.
15 years 4 months ago #5042 by adminVB
Replied by adminVB on topic 88 Cam Gear Replacement
I would suggest getting the porken timing tool if you have a 32v 928:
liftbars.com/pk.htm#32Vr
15 years 4 months ago #5045 by Slave01
Replied by Slave01 on topic 88 Cam Gear Replacement
Thanks,
Already have that and the Tensioner, lift bars, etc. Good stuff!
15 years 4 months ago #5047 by 928mac
Replied by 928mac on topic 88 Cam Gear Replacement
I would start by setting the crank at 45 deg. advanced.
For more detain on how to do the gears look in Dwaynes step by step in our technical section.
BTW what is your name?
