RR flywheel in car not moving trans
15 years 4 months ago #4810
RR flywheel in car not moving trans was created by 928mac
Here is How I removed the flywheel while the engine was in the car with out moving the transaxle.
I had forgot to mount the starter bracket before installing the flywheel and before putting the engine in the car
So, with the bell housing bolts removed, push down on the front of the engine to create a gap at the top.
Pry it open at the top and insert a wire brush handle
Dont put it in to far that it interferes with the flywheel
Jack up on the front of the engine to widen the gap at the bottom
Reinstall the flywheel and If you bought the Mac tools triple square.
And the 3/8 snap-on Torque wrench (good to 75 lbs/ft) there is lots of room to torque the bolts
I Hope this helps.
Every car is different and if you brake it, it wasn't me
I Hope this helps.
15 years 4 months ago #4823
Replied by pcar928fan on topic RR flywheel in car not moving trans
Follow the directions VERY CAREFULLY on the install of that constantine super clamp. Kind of a PITA, but do it once and never worry about it again!
