Single disk vs dual disk clutch
15 years 5 months ago #4726
by Boulet
Single disk vs dual disk clutch was created by Boulet
I realize Porsche redeveloped the older style dual disk clutch for a larger single disk but why exactly? What types of problems can be expected with the dual disk? Yes, let's hear the horror stories...
15 years 5 months ago #4728
Replied by srshaw3 on topic Single disk vs dual disk clutch
I believe the issue was that they were problematic when serviced in the field with regard to adjustment. In general there aren't issues when they are understood, and as you perhaps already know they will tolerate more hp and torque.
I retrofitted a dual disc clutch to my '90 GT and am very happy, but I had one in my '80 so knew what to expect. The effort required to operate the clutch is much less than with a single disc assembly.
15 years 4 months ago #4770
by Boulet
Replied by Boulet on topic Single disk vs dual disk clutch
Thank you Stan, I appreciate your input.
-Todd
-Todd
15 years 3 months ago #5243
by N2O-928
Replied by N2O-928 on topic Single disk vs dual disk clutch
Yes they work great however they will drag if not adjusted and maintained, the intermediate plate is held in place (floats) by three “finger like” links and they can become worn or get dirty and stick.
Devek had a great write up years ago, to put it simply; clean and use a dry lube on all three links and center the intermediate plate.
The clutch needs to be disengaged (open/peddle down) to do this.
Rotate eng until each link is at the bottom (clean lube) and center the intermediate plate, repeat two more times.
Some will say there is a measurement however that only would/could apply if all parts are new and most are not.
Dave
Dave
