1978 928 5 speed fuel pump delivery test.
My knowledge on this one, is definitely just some experience in seeing how much fuel was returned to the just installed fuel cell in my '80 Euro S.
What is the problem you are chasing?
It is a special wire, and relatively expensive
Greg Nichol's site has some great tips, particularly for an older 928 in my opinion: nichols.nu/tips.htm
vze2jshn;244 wrote: Thanks for the response. Car will sometimes start and idle correctly but stumbles, hesitates, misfires when driven. Then stalls and is hard to start. Then won't start, then might rev for a second and stall, then start and idle seemingly correctly only to start the cycle again. Checked cold start valve which was not spraying- replaced and the above problems surfaced again. I am troubleshooting now from square one.
The fuel you accumulated in your test was certainly sufficient. Pumps are fine, though that does not dismiss other fuel related faults that could be creating your rough running condition. Is the mixture noticeably rich or lean? Have you done a vacuum check?
I've been battling a vacuum leak for a while now with my '84. Car began to run very poorly more and more often. It's also worth noting that it behaved in a cycle much the way you describe and the vehicle was going between extreme lean and rich fuel mixtures. Turned out that two of the intake gaskets were creating the leak. Never overlook your intake seal as a potential fault with a rough running 928. So often, the cause is a simple, easy-to-fix vacuum leak.
