Thermostat housing cleaning
15 years 6 months ago #4257
Thermostat housing cleaning was created by 928mac
Here are a few pictures of how I cleaned it up.
before I started.
This is how I removed the inner seal
Now it is ready to start cleaning
I used a wire wheel on a Dremel
Then I used a rubber none abrasive buffer
Looking a little better ?
The stat hose housing was nasty as well
But I cleaned the edges the same way
The whole point is to clean with out damaging
Then I buffed it with the die-grinder
before I started.
15 years 6 months ago #4263
by martinss
Replied by martinss on topic Thermostat housing cleaning
Very nice serial pics Brad - very clear - thanks!
15 years 6 months ago #4266
Replied by pcar928fan on topic Thermostat housing cleaning
EXCELLENT Pics and info! You are taking lessons from Dewayne obviously!
15 years 6 months ago #4431
by xstepson
Replied by xstepson on topic Thermostat housing cleaning
Brad,
Are you going to throw some sort of clear coating on that thermostat cover so it doesn't corrode and stays shiny?
BradW buffed mine for me a couple of years ago. I sprayed it with some clear enamel and it's still shiny and looking good.
15 years 5 months ago #4782
by Pcplod
Replied by Pcplod on topic Thermostat housing cleaning
Brad,
What did you paint your thermostat housing with to give it such a bright candy-apple type of finish?
