!978 cold start up IDLE/RUN PROBLEM
16 years 7 months ago #127
by vze2jshn
!978 cold start up IDLE/RUN PROBLEM was created by vze2jshn
My "78, 928 starts but idles very low and doesnot rev and spits or pops sometimes when attempting to rev up. Can drive around the block but engine seems to be in later ecu models limp mode until after 15 minutes when eng warms and full rev power, driveability,etc.returns. I had a new warm up regulator on the shelf so replaced it -same problem. Fuel pressures are fine when warm up because it runs well then. Bosch fuel injection book doesnot mention this situation specifically in trouble shooting. Has anyone encountered and solved this problem?
Best regards, Greg
Best regards, Greg
16 years 6 months ago #155
Replied by Kiln_Red on topic !978 cold start up IDLE/RUN PROBLEM
Your symptoms are unusual for a car of your year model. If your car was equipped with the later L-jet system then I'd be suspecting the "temp II" sensor as a possible fault. Have you checked your vacuum?
16 years 6 months ago #156
Replied by srshaw3 on topic !978 cold start up IDLE/RUN PROBLEM
This would be CIS, correct?
Have you reviewed the fuel distributor?
I saw one that had problems when cold, and under load, because the filter screen in the fuel distributor line was clogged. Might be unrelated, but often it isn't recognized that there is a filter there.
16 years 6 months ago #157
by vze2jshn
Replied by vze2jshn on topic !978 cold start up IDLE/RUN PROBLEM
Isolated faulty auxiliary air valve--replaced with used one from 928 intl. This particular problem went away. Thanks for responses. Greg
