rear hatch light connector
- john a. volak
15 years 10 months ago #2038
by john a. volak
rear hatch light connector was created by john a. volak
where is the connector? interior lights will not turn off while driving or sitting still . i've changed relay but did no good. someone said it's probably the hatch electrical connector, but where is it. the car acts like the doors are open.1988 s4, automatic. thanks, john
15 years 10 months ago #2044
Replied by 928mac on topic rear hatch light connector
Do all the lights come on John?
or just one light
or just one light
15 years 10 months ago #2048
Replied by pcar928fan on topic rear hatch light connector
The connector for the pin switch on the hatch is right at the very bottom of the hatch receiver. The pin actually screws in to the bottom of the receiver and there wire that connects to it I think actually has a plug so you can easily remove the pin switch or unplug it to defeat that switch altogether if you like. One of your switches is clearly NOT working. A temporary work around is to just turn all the lights in the car off...
- john a. volak
15 years 10 months ago #2096
by john a. volak
Replied by john a. volak on topic rear hatch light connector
all the lights were working.i did find. i did find pin switch at bottom of the hatch receiver. i noticed hatch light was coming on but when i pushed in plastic joint it went off but after releasing plastic light wouldn,t come back on. when it tried to shut off it only got dimmer and wouldn't go off. it had to be in wiring , i think i have it corrected now. thanks guys, john
15 years 10 months ago #2098
Good luck John! Hope you got it taken care of! At least you know where to look for that switch now!
Best,
Best,
