Dashboard lighting - in the dark - 89' S4
1 year 4 months ago #22947 by sgfung
Hi, I have an 89' auto.  The dashboard illumination is fine during the day (i.e. when I don't turn on the headlights.)  But when I turn on the headlights, the illumination goes off.  Any idea or suggestions ?   Thank you very much.
1 year 4 months ago #22950 by sharper410
The dimmer switch probably has some corrosion built up on it. I had the same issue on my 89 when I resurrected it. Pulled the switch out and cleaned it up and it fixed it. Some people just bypass the switch all together.
1 year 4 months ago #22951 by sgfung
Thank you for the suggestion.  I will take a look at the dimmer switch.
