928 s4
1 year 5 months ago #22885 by mark.sheffield
928 s4 was created by mark.sheffield
hi all i have 928 s4 no start
cranks
spark to plugs
fule pump running and fuel pressure
ecu good as have running car i swop over
apears no pulse to injectors
last autum car started but stored out side over winter
any ideas
1 year 5 months ago #22887 by NickTucker42
Replied by NickTucker42 on topic 928 s4
Sorry for your troubles..
When you say you swapped the ECU, which one did you swap as there are 2 of them.  One is the LH which has a well documented failure mode due to a daughter board cracking over time, and there is the EZK.  LH is for fuel, EZK is for Spark.
1 year 5 months ago #22888 by mark.sheffield
Replied by mark.sheffield on topic 928 s4
thanks for the reply
the lh unit i have spark at plugs not getting fuel
1 year 2 months ago #22956 by Rich928
Replied by Rich928 on topic 928 s4
This document may assist you to understand and diagnose your problem.
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
