Injectors
2 years 6 months ago #22600 by drkshrk86.5
Injectors was created by drkshrk86.5
Want to replace injectors on my 86.5. Which is the best way to go . I'm confussed
2 years 6 months ago #22601 by Rich928
Replied by Rich928 on topic Injectors
Have you had your fuel injectors cleaned and flow tested?  They may not need to be replaced.  There are many shops possibly local to you or to be found on-line that provide that service.
Independent vendor 928sRus lists P/N 928-606-119-00 as replacement.
2 years 6 months ago #22603 by rtk11
Replied by rtk11 on topic Injectors
Roger (928sRus is a good source).  I had good luck with RockAuto and their GB Remanufactured injector when I needed to replace one.
