Manual shifting automatic
- scottydogg
5 years 6 months ago #21821
by scottydogg
Manual shifting automatic was created by scottydogg
Is there any way to manually shift between 1st & 2nd gear on a 4spd automatic. An aftermarket valve body, maybe?
5 years 6 months ago #21827
by Gary Knox
Replied by Gary Knox on topic Manual shifting automatic
This is pretty extensively discussed on the Rennlist 928 Forum. Do a search for 'first gear start'
Gary
Gary
- jonnysocko
5 years 6 months ago #21848
by jonnysocko
Replied by jonnysocko on topic Manual shifting automatic
Yes, start out with the shifter in 2. When you start from a stop it puts the trans into 1st. When you want to shift, slide the shifter up to 3 and then quickly back to 2 and it will shift to second. Just shift up to third next. Remember to hold the shift lock button down when doing the quick shift back from 3 to 2.
