Electrical connectors and aluminum and other electrical tests
16 years 5 days ago #1580
Replied by 928mac on topic Electrical connectors and aluminum and other electrical tests
checking, Starters, Alternators, fuel systems components
assets.fluke.com/appnotes/automotive/beatbook.pdf
16 years 5 days ago #1582
Voltage is like the pressure of the water in your garden hose.
The resistance in a circuit has the same effect as opening and closing the nozzle (more or less resistance)
Amperage is how much water comes out the end.
Watts, or work, is how much water goes into the bucket.
This is what one instructor said to me that finally made it click, many, many years ago.
If you are still not sure, read it again slowly.
www.autoshop101.com/forms/elec11.pdf
16 years 5 days ago #1584
www.sw-em.com/an_automotive_electrical_primer.htm
Ohms Law: V(voltage) = I(current in Amps) x R(resistance)
...or after some algebraic manipulation (I'll spare you the mathematical Kung-Fu), the derived equation for Power:
P(Power in Watts) = V(voltage) x I(current in Amps)
16 years 5 days ago #1585
