Fuel leak at Tank Valve
16 years 6 days ago #1479 by Mrmerlin
Replied by Mrmerlin on topic Fuel leak at Tank Valve
you probably have broken the seal between the inner collar inside the tank and the tank body if you can figure out a wat to reseal the collar then you may have a leak free tank otherwise tank replacement may be in your future
16 years 6 days ago #1491 by 928mac
Replied by 928mac on topic Fuel leak at Tank Valve
Mrmerlin;1524 wrote: you probably have broken the seal between the inner collar inside the tank and the tank body if you can figure out a wat to reseal the collar then you may have a leak free tank otherwise tank replacement may be in your future
Ok Merlin, at least there is a ray of hope that I can come up with a fix.
I am parking it out side for the time being and driving it to work as it is only a drip every 30 - 40 seconds.
We will have snow in 2 weeks and I will put it away and pull the tank again at which time..... Pictures,talk, Pictures,talk, Pictures, talk.
