Timing Belt and Water Pump service gone wrong!
9 years 1 month ago #19901
by noah12142
Timing Belt and Water Pump service gone wrong! was created by noah12142
Hi,
Started my timing belt and water pump service smoothly by quickly encountered some issues rotating the crank counterclockwise to 45 degrees to TDC instead of clockwise. I then removed the belt without understanding my mistake and my cams are not in position either. To make it worse, my drivers side cam has since moved maximum 4 teeth, probably 2 teeth. How do I fix this? My only guess would be to attach the new timing belt and tensioner and rotate the crank until the cams are at TDC and the crank is at 45 to TDC and hope I dont bend a valve. Please help!
Cheers and Thanks,
Noah
Cheers and Thanks,
Noah
9 years 1 month ago #19902
by noah12142
Replied by noah12142 on topic Timing Belt and Water Pump service gone wrong!
Here are some pictures:
9 years 1 month ago #19904
by Johnnyts
Replied by Johnnyts on topic Timing Belt and Water Pump service gone wrong!
It's important to know what you do when setting the time, especially when replacing the timing belt, rather get someone that knows how to set the timing properly on these cars.
hope you sort it out.
rgds
Johnny
rgds
Johnny
9 years 1 month ago #19907
by noah12142
I'm more looking for an actual solution rather than the "take it to the mechanic".
