Putting staggered S4 rims on an 86 S?
9 years 6 months ago #19718
by LAnNYCGuy
Putting staggered S4 rims on an 86 S? was created by LAnNYCGuy
Hello,
So, the 85/86 cars came w/ 16X7s fronts and back (with a spacer in the rear, yes?) w/ 225/50s all the way around, correct?
Can one update to the S4 (same style) staggered 16X7 front and 16X8 rear w the wider 245/45s on the back? Assume NO spacer needed now?
Any fit issues?
Fit aside, any handling issues?
Better? Worse? Wash?
Thanks.
Any fit issues?
Thanks.
9 years 6 months ago #19721
Replied by Kiln_Red on topic Putting staggered S4 rims on an 86 S?
You describe the exact setup on my '84. No extra work necessary. PERFECT fit.
9 years 6 months ago #19722
by LAnNYCGuy
Replied by LAnNYCGuy on topic Putting staggered S4 rims on an 86 S?
Thank you! Wheel spacer used/needed in the back? Or when you go 1" wider, not needed?
9 years 6 months ago #19723
The 8" wide wheels in the rear is what they all should have come with originally. They look so much better. Leave the original spacers alone.
LAnNYCGuy wrote: Thank you! Wheel spacer used/needed in the back? Or when you go 1" wider, not needed?
