Is The JDSPorsche LH2.3 SharkTuner
16 years 1 month ago #1293
Is The JDSPorsche LH2.3 SharkTuner was created by 928mac
Is The JDSPorsche LH2.3 SharkTuner the best scan tool for our cars.
What are the other scan tool options.
16 years 1 month ago #1294
Replied by srshaw3 on topic Is The JDSPorsche LH2.3 SharkTuner
The 928 OC has the original form of the 928 Diag tool.
I don't know which is better for scanning.
I thought the JDS tool could be used for tuning as well.
The Porsche Hammer is another scanning tool.
16 years 1 month ago #1295
Replied by 928mac on topic Is The JDSPorsche LH2.3 SharkTuner
Yes Stan it says that it can be used for tuning as well.
I guess thats what would make it more valuable and expensive.
Man that is a lot of Cash to fork out plus the extras which in my opinion there is no use in only buying half of something.
16 years 1 month ago #1343
by hilton
The Sharktuner isn't really a scan tool - it won't read the ecu fault codes or run through the diagnostic procedures for testing all the various inputs. You can infer many of them however when using a Sharktuner (e.g. knock/hall sensor faults can be inferred by watching the timing retard, or throttle switch not detecting WOT etc.).
JDS also make a tool called the "Spanner" which is equivalent to the Bosch Hammer and will read 928 fault codes, run idle adaption routines, reset airbag faults, test all the sensors, actuators and ecu inputs (e.g. AC switch idle compensation, or Idle Stabiliser Valve tests with engine off). There is also Theo's diagnostic software which does the same as the Hammer/Spanner and runs on a laptop (which is what the OC bought).
I have a Sharktuner II, and a local mate has a JDS Spanner.. both are useful.
Replied by hilton on topic Is The JDSPorsche LH2.3 SharkTuner
928mac;1332 wrote: Yes Stan it says that it can be used for tuning as well.
16 years 1 month ago #1357
by SeanR
Replied by SeanR on topic Is The JDSPorsche LH2.3 SharkTuner
We've got both the Bosch KTS (Hammer) tool and the shark tuner. For everyday diagnosis, the hammer does it best. The ST is used more for tuning.
