window/sunroof controller on 1994 GTS
9 years 11 months ago #19372 by n9598m
we just replaced the window/sunroof controller under the drivers seat
the original part number on the car is: 928 618 240 00 the replacement part from Porsche is: 928 618 040 00
When the replacement part was installed the driver window switch when pressed now controls both the driver widow and the sunroof
When the sunroof switch is pressed it does the same as the driver window switch - operates both the driver window and sunroof
Thus the driver window and the sunroof cannot be operated independently
The passenger window switch operates normally
is there a solution to this problem in the wiring and/or pins on the connectors to the controller?
