Has Anyone Put A 89 Engine IN 86 Car ?
10 years 4 months ago #19062
by Dragonrob
Has Anyone Put A 89 Engine IN 86 Car ? was created by Dragonrob
Hi I am new to this forum. I have installed a 89 engine and harness, computers in my 86 928 I was wondering if someone else has done this and if they can give me some tips on what needs to be done with the harness to make it work I would appreciate any help and advice I can get. Thanks Rob.
10 years 3 months ago #19091
Replied by Kiln_Red on topic Has Anyone Put A 89 Engine IN 86 Car ?
If you have the engine harness, EZK and LH 2.3 modules and their respective harnesses, then this should be a plug-n-play. Where are you finding a snag?
10 years 3 months ago #19092
For future reference, I would suggest to start this sort of topic in the Technical Discussion Forum where I would expect you might have better luck with suggestions.
10 years 3 months ago #19093
by Dragonrob
Replied by Dragonrob on topic Has Anyone Put A 89 Engine IN 86 Car ?
I put in the 89 harness and computers and I have not been able to get spark or fuel injection to work I don't know why it won't work. I am at the point of giving up I traced wire's that needed power and connected them and still no luck if I knew it would not have worked I would have went with a 86 engine. Some people on rennlist said they knew how but never said anything else so I have just left it sit for now.
10 years 3 months ago - 10 years 3 months ago #19094
There is a 2-pin plug (1 green & 1 white wire) that sometimes is forgotten about during engine R&R jobs. This is from the EZK and it must be plugged in to have spark. Make sure that the connectors aren't pinned behind the CE panel and that the plug isn't disconnected. I've seen this a couple of times. The male and female connectors should be easily located at or around the CE panel.
Dragonrob wrote: I put in the 89 harness and computers and I have not been able to get spark or fuel injection to work I don't know why it won't work. I am at the point of giving up I traced wire's that needed power and connected them and still no luck if I knew it would not have worked I would have went with a 86 engine. Some people on rennlist said they knew how but never said anything else so I have just left it sit for now.
Last edit: 10 years 3 months ago by Kiln_Red.
